PXI
PXIe read trigger timestamp for 'real' t0
I looked for a post that addressed my problem, but I couldn't find one that quite answered my question.
Based on the below link, the timestamp returned by DAQmx from a `DAQmx Read` operation is indeterminate relative to when its corresponding data was taken:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P9Q9SAK&l=en-US
In my system, I have a PXIe 1085 chassis with a 6674T in the timing slot, a 6683H time reference in slot 9, and many 4303 ADC cards. I send a Global Software Trigger as my Start Trigger from the 6674T. The software trigger is connected to many lines/ports, but the relevant one here is PXI_Trig1. I use `niSync Enable Time Stamp Trigger` and `niSync Read Trigger Time Stamp`  on the 6683H to capture the rising edge of the Start Trigger on PXI_Trig1. I would like to use this as my t0 instead of the one coming from `DAQmx Read`. In my testing, I expected this t0 to be a few microseconds off from the actual time of the first acquired sample (due to the time to ready internal buffers), but I’m observing a lag on the order of 100s of milliseconds (with 1-5 ms variance). To test, I use a PPS signal coming from the 6683H fed into a channel of one ADC to see if the rising edge of the PPS signal lands exactly on the second.
So then, is there a way to know the dt between when these ADC cards receive a Start Trigger and when they start filling up their internal buffers? Is it really 100s of milliseconds?
(2,357 Views)
Hi KingWeasel11,
You said that you have a 6674T in the timing slot and a 6683H in slot 9 inside your 1085 chassis, but slot 9 in this chassis is the timing slot. Can you confirm this or tell me which slot the 6674T is in?
PXIe-1085 User Manual (pg. 1-4 shows the slots)
http://www.ni.com/pdf/manuals/373712j.pdf
Garrett W.
(2,310 Views)
I think you got tricked by the labeling. It got me the first time as well. It's circle number 9, but it's pointing to slot 10 if you zoom in
(2,304 Views)
