PXI
PXIe1088/PXIe-8880 Remote Control Requirements
I have a PXIe-1088 chassis with PXIe-8880 controller and would prefer to interact with the system via a Windows-based PC. I believe I need a Remote Control Module to do that (something like the PXIe-8301), but don't explictly see a compatibility table indicating it would work with the 1088 and when I try to use the NI Configuration Advisor, it only allows me to add either the PXIe-8880 or PXIe-8301, not both. Can I assume the 8301 works with any PXIe chassis and controller module?
(1,764 Views)
To clarify, PXIe-8880 is a controller, in other words, it is an industrial rugged PC. Having said this, you would not need another computer to control a computer.
You directly connect the monitor, keyboard, ethernet to the PXIe8880 and start using it as a PC that can directly control the PXI instruments in the chassis.
You go for PXIe-8301 when you don't want to invest in a PXI controller and not when you already have one. PXI controller is the best and highest performance means to interact with the PXI modules.
Both PXIe-8880 and PXIe-8301 plug into the system controller slot (which is only one per chassis), this means you can have either this or that but not both.
Santhosh
Soliton Technologies
(1,708 Views)
Thanks, santo_13. Does that still hold true if I'm needing to operate the 8880 as a real-time controller? The thread below seemed relevant.
Connecting PXI-8880 to Labtop via Ethernet - NI Community
(1,706 Views)
I am not familiar with RT/Linux on the PXI controller but given the HW is still similar to the windows version, you would have to control this over the network.
If it were a windows controller, it would have been simple as logging into a computer over RDP/VNC/TeamViewer and doing whatever is required.
Based on details from the below link, you would have to add the RT controller as a remote system in NI MAX of the laptop from which you want to control it.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019LSXSA2&l=en-US
Santhosh
(1,685 Views)
