PXI
PXIe8301
I would like to confirm if the PXIe8301 module is compatible with the NI PXIe1073 and PXIe1033 chassis, this is for calibrating PXIe7732 and PXIe4080 modules in the laptop.
(226 Views)
PXIe-8301 is compatible with any PXIe (note the "e") chassis that has an open controller slot (slot#1) but not compatible with PXI chassis
🚫PXIe-1073 - has an integrated controller and no Slot#1 and hence not compatible with 8301
🚫PXI-1033 - not compatible with 8301 due to different bus protocol PXIe vs PXI
Santhosh
Soliton Technologies
(217 Views)
As Santo_13 mentioned, PXIe-1073 already comes with an integrated controller hence you only need a host interface card.
  1. To use with laptop, you need a laptop with ExpressCard slot and an ExpressCard-8360. The ExpressCard has long been obsoleted and is not available on most modern laptops.
  2. Use PCIe-8361/2/3 but this can only be installed on a desktop.
If you have a laptop with Thunderbolt port (Thunderbolt, not Type-C), you can get a 2-slot PXIe-1090 chassis.
https://tmesystems.net/
(160 Views)
