PXI
PXie 4844 missing files
Hello.
I am fairly new to the PXI system. I am trying to configure sensors connected to the PXie 4844 using the NI-OSI Explorer.
When I launch the OSI explorer (or when I try to use a OSI .vi in Labview) it loads some files, then prompts me to find nirssg.dll in my directory, which is not available on my computer. Also when I ignore this item, and launch the explorer, it has the following error listed: Missing subVI osi_Read Custom Flash Attributes.vi in osi_Check Firmware Version.vi" I have attached pictures of what I see when I try to launch the OSI Explorer.
I know this system is outdated, but any help would be appreciated.
(430 Views)
You will need to install the OSI drivers https://www.ni.com/en/support/downloads/drivers/download.ni-osi.html and use a LabVIEW version that is supported by the OSI driver
Santhosh
Soliton Technologies
(413 Views)
I was able to find the file I needed from an external website, it is now running well.
(379 Views)
Documenting how you solved it will help others with the same situation.
Santhosh
(374 Views)
