10-22-2025 01:00 AM
I have connected a PXIe-2527 card to a PXIe-1078 Chassis but on MAX the card shows up as /sys/bus/pci/devices/0000:0a:00.0 on NI max. The card also shows upn outside the Chassis subsection and only part Devices and Interfaces.
I have LINUX RT system image for Q1 2020 running on my PXIe RT card. Is it a driver Issue if yes do I have to update the driver on my
10-22-2025 01:02 AM
This may be due to NI MAX corruption, please try resetting NI MAX as per Reset and Fix the Measurement & Automation Explorer Database File - NI
10-23-2025 11:45 PM
The reset will fix NI MAX corruption only on the host PC and not he RT.
sadly this could not be the solution
