PXI
Packet transmit by RFSG ?
Hi, everyone. I want to send the packets continuously by 5673E, my code just as the attachment. But there is an error
´íÎó-1074118136·¢ÉúÓÚ niRFSG Write Arb Waveform (Complex DBL).vi
The AWG reported the following error:
You cannot write data outside the boundaries of your waveform.
Make sure you are not trying to write more data than your waveform can
accomodate and that your write location and write offset are set
correctly.
Status Code: -200311
I can remove the error by the picture show, but the data would not be transmitted as I wish.
Thanks for any help!
Message 1 of 1
(5,105 Views)
