PXI
Perform VIH/VIL Test using SMU Sequence Functionality
I want to perform VIH/VIL Test for a certain device. I'm thinking of configuring the Source Mode to Sequence for Channel 0 (VIN). This will perform a ramp of VIN from 0V to 5V with 0.1V increment. But, I cannot figure out how to simultaneously perform measurement (synchronized) on Channel 1 (VOUT) for every step (sourcing from 0V to 5V with 0.1V increment) in the sequence performed on Channel 0 (VIN).
My aim is to get the results faster by removing the communication latency between the host computer and SMU among each measurement of a sequence. I'm actually using NI-DCPower Hardware-Timed Two-Channel Voltage Sweep.vi as my reference.
I hope someone can help. Thanks!
(2,877 Views)
Hey runwaydavey,
I am guessing you saw this white paper:
http://www.ni.com/example/30950/en/
Which SMU are you working with?
Chase
NI Technical Support Engineer
(2,848 Views)
