PXI
Phase locking on the PXIe-5171R
Hi everyone,
I have what is most likely a fairly straightforward question since I am relatively new to working with the PXIe-5171R. We have a 10MHz external timing card that we are trying to use to improve the timing stability. I understand that one can attach a 10MHz external clock through the CLK_IN, but is this also phase-locked to the PXIe_CLK100? And if not is there a way to use the external clock to synchronize the Data Clock and the PXIe_CLK100?
Thanks!
Message 1 of 1
(1,141 Views)
