11-24-2007 11:21 AM
11-26-2007 10:10 AM
11-26-2007 10:58 AM
I am using NI-PXIe-1062Q Chassis. Basically I want to build a portable RF Application development Platform. I hav already mentioned that I am using RF bundle for this purpose. Basically I have offered a system in competetion with N5182A MXG Vector Signal Generator to my client. I also want to give them option for mobility for that purpose i want to give them a bettery option. I hope that gives you some idea what i am looking for.
Thanks. Roman
11-26-2007 11:24 AM
11-27-2007 12:27 PM
11-28-2007
10:41 AM
- last edited on
05-13-2024
08:56 AM
by
Content Cleaner
Roman,
Currently the the NI MKD-1117 kit includes the following items:
• An NI MKD-1117
• A rack-mount kit
• A U.S. 120 VAC power cord
• A VGA and dual-PS/2 cable
• A USB-to-dual-PS/2 adapter cable
The PXIe-1062Q will also require the rack mount kit as well. This can be purchased from the PXIe-1062Q Product Page. Currently this chassis is recommended to run off of AC power, but with the proper power converters it should work, but the battery life is not tested.
If you do decide to use this setup, you will need to purchase a rack that will accommodate these two pieces of equipment. We currently do not offer one at this time.
Currently the only DC Powered Chassis is the PXI-1031DC, but it only has 4 slots, and the current chassis you are using has 8. It is also not an Express chassis. For more information on this, please reference the PXI-1031DC Product Page.
You are always welcome to fill out a product suggestion if you would like to recommend an alternative chassis for future development. If you would like to do this, go to the Product Feedback Section on the Contact NI Page.
11-28-2007 10:45 AM
Sarah, I am looking for a comparison between NI PXI Based RF solution and Agilent N5182A MXG Vector Signal Generator. I know the benefits of modular system but I would like to see a presentation or an article on this which I can refer to my client. Please advice me on this. Basically the client want to buy Agilent Signal Generator but I want to offer them PXI based NI Solution. I look forward to your advice. Thanks
Roman
11-29-2007
06:07 PM
- last edited on
05-13-2024
08:57 AM
by
Content Cleaner
Hi Roman,
If you are interested in a PXIe solution I would suggest the PXIe-5672 Vector Signal Generator. The specs of the NI product do not exactly overlap with the specs of the N5182A MXG Vector Signal Generator. However, based on the project requirements the PXIe-5672 might be a good fit. I was not able to find a paper that does a head-to-head comparison between the two devices. If I find anything more relevant to your case I will let you know.
I can arrange your local field sales engineer to give you a call. You can email your contact information to support@ni.com and include a link to this discussion forum post. Specifically request that the email is forwarded to me. Regards,
11-30-2007 01:11 PM
Hi, I have configure the PXI as per following specs please have look at it and advice. Please note because I have used NI PXI 6.6 Ghz
RF Signal Generator that is why I have used the agilent N2100B 8.5 Gb/s Analyzer. Please advice me if technically it is workable.
Vicky
| 1 | 779730-01 | |
| 2 | 763000-01 | |
| 3 | 780031-01 | |
| 4 | 779782-02 | |
| OR | ||
| 5 | N2100B | PXIT 8.5 Gb/s Digital Communication Analyzer |
| 6 | 779670-02 | |
| 7 | 780066-01 | |
| 8 | 780064-01 | |
| 9 | 779465-01 | |
| 10 | 776671-09 | |
| 11 | 71⁄2-Digit, 26-Bit, 1000 V Digital Multimeter and 1.8 MS/s Isolated Digitizer |
12-03-2007
11:08 AM
- last edited on
05-13-2024
08:58 AM
by
Content Cleaner
Hi Vicky,
As Kalin suggest above, I would recommend the local engineer help you out on this one. I think you are comparing two different devices here:
The VSA will usually downconvert and analyze a defined bandwidth in amplitude and phase. The DCA is for digital signals and usually will not downconvert. Which instrument do you need? What is the type of measurement you are trying to perform?
Again, as Srdan suggest in your other post, you will need to provide more details on what you are trying to accomplish. If this is not public, you can always call or email directly support at ni.com/ask.
I have included more PXI specific documents in a response to other of your forums here.
