PXI
Power Suppy Problem at PXIe-1062q
Hello to all,
I have got the second failure with a power supply at a PXIe-1062q-Chassis.
Does anybody know a general problem with this device?
After turning on the Chassis something sparks inside and the POWER OK LED of the Controller keeps blinking.
Thank you for Information.
(4,284 Views)
Hello HF-Walter,
in the user manual you will find the following set of informations:
• If the inhibit switch LED is steady green (not flashing), the chassis is powered on and operating normally.
• If the inhibit switch LED is flashing green, the air-intake temperature as exceeded the chassis operating range.
• If the inhibit switch LED is flashing red, the power supply outputs are not within voltage regulation requirements.
• If the inhibit switch LED is steady red, the system fans or power supply fan has failed. The remaining fans will automatically be driven high.
I think in your case it´s the second bullet. Please check if your fan work fine and is not covered with anything. Also the chassis should not be covered with anything. Did the chassis stay in a warm environment? Please send me your adress and phone number to Jan.Kniewasser@ni.com to clearify the details if we have to replace or repair your power supply.
Best wishes, Jan Kniewasser
Jan Kniewasser | Applications Engineer | Tel.: +49 89 7413130 | Fax: +49 89 7146035
(4,268 Views)
Hi, my problem is the third bullet. How can i fix that problem?
(2,879 Views)
