PXI
Problem reading serial number on PXI
Hi ,
I'm using LabVIEW to get  access programmatically on hardware informations on my PXI using the System property Node.The informations I'm trying to retrieved are the following.
  1. SerialNum
  2. ProdName
  3. Slot
My actual configuration is
Slot 0 : Chassis PXIe-1082,SN:305630A
Slot 1 : Controller PXIe-8135, SN:2F25FD89
Slot 5 : PXIe-6674T, SN:00F5929A
Slot 6 : PXI-6683H, SN:0198D955
Slot 8 : PXIe-7971R, SN:01BC305D
This is what I get from the System hardware property node
Slot 0 : Chassis PXIe-1082, SN:305630A
Slot 0 : Controller PXIe-8135, SN:2F25FD89
Slot 1 : Controller PXIe-8135, SN: None
Slot 4 : PXIe-6674T, SN:00F5929A
Slot 5 : PXI-6683H, SN:0198D955
Slot 7 : PXIe-7971R, SN:01BC305D
I can not understand why my controller is appearing on two differents slots  and only one of them has a serial number.Also I find the same behaviour using MAX .
Does anybody came accross this problem before ?
(3,055 Views)
Hi julien,
How are you accessing to your hardware information? Could you attach a screenshot of the MAX information as well as a snippet of your code?
(3,016 Views)
Hi ,
I'm accessing to the hardware information using the System hardware property node. I've linked a  screenshot of my code ,front pannel and MAX .
As you can see on the front panel I'm reading  the PXIe-8135 and serial number on the slot 0  but on MAX I'm detecting the PXIe-8135  on slot 1 with no serial number.
(3,012 Views)
Where are you getting your references from? Is this a shipped example? Also I would expect only the active devices to be found and not the 6674T for example.
You could try to reset the MAX Database to eliminate all old configurations (make sure to save the settings beforehand if you would like to load them later)
(2,987 Views)
