PXI
Problem with Cal Exec 3.0.1 & PXI-4070
I get the following error when running the Cal Exec calibration procedure for the PXI-4070 when it gets to the Verify AC Voltage test
Error -1074001424 occurred at Error -1074001424
occurred at cex_FL5XMCal_ConfigCalibratorOutputAndWait.vi
Possible reason(s):
Value not available
This error code is undefined.
 No one has provided a description for this code,
 or you might have wired a number that is not an error code to the error code input.
Setup
Cal Exec 3.0.1 running on WinXP
PXI-1042 Chassis
Fluke 5520A Calibrator
Help please
(3,300 Views)
I found this posting that may answer your question:
http://forums.ni.com/ni/board/message?board.id=140&message.id=11441&requireLogin=False
It looks like one of the VIs the Fluke 5520A driver uses involves an older version of NI-VISA functions and needs to be replaced with the new ones from NI-VISA 3.3.1.
(3,286 Views)
