PXI
Problems with NI PXIe-1095 chassis and DAQmx vis.
Dear Community,
We have a NI PXIe-1095 chassis and a bunch of modules installed in it (NI PXIe-8880, PXIe-5764, PXIe-6674T, PXIe-7976R and NI 1483 installed in the latest). The PXIe-6674T was used for synchronization of the PXI chassis and modules to the external triggers and clocks.
To route signals withing shassis I used "NI DAQmx Connect terminals.vi". Till yesterday, everything was fine with it but suddenly (no updates or upgrates) I got the following problem. The lists of terminals this vi offered to route (source and destination) suddenly reduces to only those ones, which are available on PXIe-6674T. All the others, like SMB, and PXIe-5764 sources and destination, are just gone. Even the chassis triggers (Trig0, Trig1...).
Moreover, in the FPGA project I was working on, the PXIe-5764 got a couple of errors: LowLatencyBuffer error and HostMemoryBuffer error.
Does someone have any idea how to proceed to solve the problem?
I expected that the problem is on LabView site and fully reinstalled it and drivers, but it did not help.
Moreover, NI MAX does not show any problems with the modules and all the selftests passed.
Thank you all in advance!
PS. Labview 21.0, Windows 10.
PPS. Since a couple of month I found that Windows shows wrong time. I thought it is due to the old BIOS battery, but its replacement (a month ago) did not help. Time synchronization is on, but does not help as well.
(793 Views)
Reinstallation of Win helped!
Have no idea what was wrong...
(727 Views)
