PXI
Proper way to configure a setup
Hello
I just upgraded windows from 7 to 10 on PXIe-3975 thats in PXES-2301 Chassis it has 4 DAQmx cards in it and I wonder whats the proper way to configure a setup? Should I start with PXIe-3975 drivers then go to chassis drivers or the other way around?
All I could file is this page: https://www.ni.com/getting-started/set-up-hardware/data-acquisition/pci-pxi
I know its all from ADLink but since they dont have a forum (at least I couldnt find one) I am coming here.
Thank you in advance!
(1,393 Views)
Worth noting PXIe-3795 for windows 10 has only one driver and its ADLINK PXI Platform Services Ver 21.02 if it would have windows 7 it would be pretty plain and simple to install all the chipset/gpu etc.
(1,387 Views)
It is sad that ADLINK doesn't have a forum or a simpler support method.
 Anyway, assuming that things would be similar to how we set up NI stuff, you would start with LabVIEW then the device drivers.
Santhosh
Soliton Technologies
(1,349 Views)
So I did. After instalation of all drivers even from third party websites Windows is still unable to recognise one of the two installed devices.
And that one device is that PXES-2301 (I think), heres the device ID: PCI\VEN_144A&DEV_348A&SUBSYS_348A144A&REV_A1
Also I cant find my PXES-2301 in ACE software. Is this possible that they withdraw support for that chassis?
Has anyone ever came across such problem?
(1,345 Views)
