PXI
Properties not Visible in MAX
I'm working on a PC that isn't connected to the Internet so it may be an old version of MAX.
I have a NI-2627 switch that I need to change the topology of from 32x2 to 64x1. When I open MAX and right-click on the card, the only options I get are: Save, Rename Alias, Delete (greyed out), and Open VISA Test Panel.
Version is 4.6.2f1
How do I change the topology of the switch if I can't get to it in MAX? Thanks.
(5,180 Views)
Hello Erin,
Welcome to the NI Discussion Forums! Like you said, there should be an option called “Configure” in MAX when you right click on the card.
However, please remember than you can configure it programmatically with the “niSwitch Initialize with Topology.vi”
I Hope this helps.
Daniel REDS
RF Systems Engineer
Help us grow.
If a post solves your question, mark it as The Solution.
If a post helps, give Kudos to it.
(5,159 Views)
