PXI
Pxi 1085 start up problem
Hello, I am new here, I have a pxi 1085 chassis Friday afternoon no problem but this morning when I tried to startup Equipement start and right after shut off. I have the all three led chassis red blinking. Do you think it could be the controller. What I don't understand is the fact all three led blink... Thanks for your advices and sorry for my approximative English I m French
Regards
Message 1 of 10
(4,576 Views)
Bonjour Corback,
Are you sure your chassis is powered on correctly?
I found this documentation that should help you:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000PASaSAO&l=en-US
Bonne journée Robot Happy
Armando
Message 2 of 10
(4,555 Views)
Hello, thanks for your reply
My power supply is -OK after take off all modules and let just my 8135 i saw the problem come from him. When i put the 1085 in inhibit manual mode (all module even 8135 take off) the 1085 start correctly and all led are steady green. The 8135 control the power supply and so shutdown my 1085 during startup. I tried to launch in safe mode (with the switch 2 on) and this is the same. Does anyone have an idea ? can i put the 1085 inhibit in manual mode and start the 8135 ?
Regards
Message 3 of 10
(4,550 Views)
Bonjour Corback,
Aucun problème.
Your controller might be effectively be the problem then.
Have you got an image to restore it? Which OS do you have on it?
It might be necessary to send it to repair.
Bonne journée à vous,
Cordialement,
Armando
Message 4 of 10
(4,546 Views)
Bonjour Armando,
Do you think i could put the 1085 inhibit in manual mode to force the 8135 power up ? or it's not advised
JC
Message 5 of 10
(4,542 Views)
Hello Corback,
Yes, there is normally no problem as long as this option is dedicated for this purpose.
Have a very nice day.
Armando
Message 6 of 10
(4,533 Views)
Follow this i just received a new controller 8135 but this is the same issue. I think the chassis is the root cause. Is someone has the explanation of "port_good" LEDs on 8135.
Message 7 of 10
(4,468 Views)
Hello Corback,
Sorry for the delay.
Ifound nothing regarding your message.
Can you send the controller for Reparation process?
Have a nice day!
Armando
Message 8 of 10
(4,372 Views)
Hello Armando, no prob.
Our controller was - OK it was the 1085 chassis the root cause. Think one voltage was out of spec or something. With a new one its OK. We will sent the chassis on rep. Thanks for helping me.
Regards
Message 9 of 10
(4,370 Views)
you are welcome!
Yes, I meant chassis 😉
Have a good one!
Message 10 of 10
(4,366 Views)
