PXI
Pxie-5162 10bit fetch data with I16
When I used a 10-bit acquisition card to collect,in the NI-scope, how does the fench function convert data to I16 data, and if I need to get an accurate amplitude, what compensation calculations do I need to make?
(3,781 Views)
The 10-bit is the resolution of the PXIe-5162, and this corresponds to the precision (smallest voltage change it can detect).
This link explains the specifications of oscilloscopes: https://www.ni.com/en/support/documentation/supplemental/17/specifications-explained--ni-oscilloscop...
In terms of accuracy, you may refer to this calibration procedure for the PXIe-5162: https://www.ni.com/docs/en-US/bundle/pxie-5162-cal-pro/resource/373910f.pdf
(3,764 Views)
thank you for your answer. What I want to know is how the collected data is converted from 10 bits to 16 bits, so the data output by the fetch function becomes a 16-bit binary number.
(3,761 Views)
I don't really understand what do you mean by collected data is converted from 10 bits to 16 bits. Is the result displayed in 16-bit binary number? Do you have a screenshot of your program and results?
(3,755 Views)
hello,
  The Tetch function can retrieve data and return a one-dimensional array of binary 16-bit values,but my Pxie-5162 is 10-bit values,so how does this function implement this conversion?
thank you.
(3,747 Views)
Good day!
The 10-bit in PXIe-5162 represents the resolution and not the way data is read or stored. I hope the screenshot below is able to clarify your question.
(3,744 Views)
Ok, thank you for your answer.
(3,737 Views)
