PXI
RF Transmission of high speed data
    Please suggest a suitable means for achieving the following.
Need to acquire analog signal at a sampling rate of at least 700 Khz and ADC resolution of 20 bit or more. The signal obtained should be transmitted over RF to a range of at least 20Km with minimal latency. Kindly advise suitable hardware.
Please advise.
Thanks for reading.
(1,457 Views)
Hello.
The maximum resolution NI Ettus devices can provide is 16-bit.
Also, transmitting to different distances depends on the used frequency, also the area you want to transmit in (City, Suburban, Urban, Rural), taking into consideration the facing obstacles and difference in terrains which affects Radio transmission.
Thank you.
(1,260 Views)
