PXI
RFSA, SCOPE & FPGA
I just found some examples available in Labview Modulation that can
perform BPSK demodulation, such as "MT RFSA PSK Demod" and "MT niScope PSK
Demod".
I'm wondering about the outcome difference of BPSK demodulation performed
by RFSA(NI 5660), niScope and Labview FPGA?
Yang
(3,743 Views)
Hi Yang -
The Modulation Toolkit VIs are simply used for caculations on acquired data.  As long as you feed them the right data, you'll get the desired output.  How you acquire it is pretty much up to you, though.  You can use either the RFSA driver or the 5660 driver.  (Note that, even though the example program you mentioned is called "RFSA", it actually uses the NI-5660 driver.  This driver is built from the Scope and Tuner drivers, as you can see when you open any of its VIs.) The RFSA driver is newer and much easier to program, as you can see from the drastically reduced complexity of its example programs.
I'm not sure what you mean by LVFPGA...can you explain how you would use that?
David Staab, CLA
Staff Systems Engineer
(3,715 Views)
