PXI
RS422 Serial Card with RTX64 Support and 3.6Mbps Baud Rate
We are currently working on a real-time application using RTX64 by IntervalZero, and we are  looking for an RS422-compatible serial card that meets the following requirements:
 Supports a baud rate of at least 3.6 Mbps
 Compatible with RTX64 (v3.x or later)
 Preferably PCIe interface ( such as PXI-8431/8) , but open to other options as well.
 Could you please recommend one or more models that meet these specifications?
Do you have code sample that we can use in our RTX64 application ?
Best Regards,
Efrat Gur
(471 Views)
Hello!
For an RS422-compatible serial card that meets your requirements, you might consider the Perle UltraPort SI PCI Serial Card, which supports RS422 and baud rates up to 3.6 Mbps. Another option is the Sealevel 7404EC PCIe Serial Card, which offers RS422 compatibility and high-speed data rates.
Regarding RTX64 code samples, you can check out this NI forum discussion for insights on integrating RS422 with RTX64. If you need specific implementation guidance, let me know!
(452 Views)
Thank you.
I am looking for a serail card that supports RTX64 .
The driver of this card should be a rtss driver or a code sample that can be integrated to the rtss software.
Best Regards,
Efrat Gur
(442 Views)
