PXI
Re: PXIe-1073 connected but not detected Ubuntu lspci or hardware confit utility.
The pxie chassis is not detected by lspci or lsni -v. the latter shows all required libraries installed like daqmx and pix services. Hardware config utility also does not detect. How to get around this issue? I am running Ubuntu 22.04.2 and installed driver version 2023 Q1
(1,000 Views)
Hi viswa99
I guess this is a problem of compatibility. Based on PXI Platform Services 21.0 readme file, the software for the Linux/x86 64-bit architecture has been tested on the following distributions:
  • openSUSE Leap 15.2
  • openSUSE Leap 15.1
  • Red Hat Enterprise Linux 8
  • Red Hat Enterprise Linux 7
  • CentOS 8
  • CentOS 7
  • Ubuntu 20.04
  • Ubuntu 18.04
PXI Platform Services requires a 64-bit distribution and does not support 32-bit applications.
As you can see PXI Platform Services 2023 Q1 and 21.0 are not supported by Ubuntu 22.04.2 version.
Regards)
(977 Views)
