PXI
Reading DAQ inputs
Hi
Attempting to read anologue inputs and recieve an error when trying to link from DAQ Assistant in LABview.
Error message reads
Labview: an exception occured within the external code caused by a call library node. This might have corroupted labview memory. Save any work to a new location and restart labview.
VI "BlockletContainerState 14.vi" was stopped at node 0xA10 of sub VI "DAQmxAssistant_DAQmxCreate AI channel (sub).vi"
I have tried moving my files, starting from scratch and linking to different I/O's.
Opperating System:
Chassis= PXI-1042Q
Controller= PXI-8196
Modules= PXI-8430, PXI-6602, PXI-6259
I/O block= SCB-68
Any help appreciated thanks
Dave
(3,261 Views)
Hi Dave,
I think the first thing to try here would be a reinstall of DAQmx. Also it may be worth trying it with just the 6259 installed in you PXI so we can eliminate the other cards from the problem. It may also be worth installing the 6259 in a different slot to what it currently is in.
Try those things and let me know how it goes.
Kind Regards,
Jas.W
Jason W.
National Instruments UK & Ireland
(3,241 Views)
