PXI
Requesting feedback from NI system Advisors
Regarding the Configuration ID  PX6327408
The system as presently configured  has a PXIe-8821 controller with
the 2 modules below
783131-01 PXIe-4082 6 1/2 Digit DMM and 300 V Digitizer with L and C
780587-69 PXIe-2569 PXI Relay Module, SPST (open), 100-Channel, 100 V,
779038-01 LFH200 Connector to Bare Wire Switch Cable, 2 M
I have a laptop w/ Lview Professioal Development system which is used to generate executables for running on remote platforms.
My question is : when developing code for the chassis on the laptop w/ the 2 modules above, is it possible to communicate with the modules through the PXIe-8821controller or how can i communicate with the modules to exercise & experiment with controlling the modules? is a separate card needed??
Also for the relay module do I need a terminal block module in addition to the the LFH200 ?
Message 1 of 1
(1,049 Views)
