PXI
Resource Conflict on Startup -> WinHost does not find FPGA-Modules
i'm using a PXI - Controller with two FPGA - Modules. On Startup, the BIOS shows me:
WARNING
ERROR
Resource Conflict - PCI on Motherboard
Bus:01, Device:06, Function:00
WARNING
ERROR
Resource Conflict - PCI in slot 04
Bus:01, Device:0D, Function:00
WARNING
ERROR
Resource Conflict - PCI in slot 02
Bus:01, Device:0F, Function:00
Press <F1> to resume, <DEL> to enter SETUP
After Resuming, my Windows-Host recognizes the PXI-Controller, but not the FPGA - Modules.
I've already tried to put the FPGA-Modules in different Slots. The error for the Motherboard resists also if there's only the controller in the chassis.
thx i.a. for your advices, mike
Hardware
Controller: PXI-8176
Chassis: PXI-1031
FPGAs: PXI-7813R
Software:
Labview 8.2
(5,599 Views)
Hi mikepxi,
I searched for a solution of your PXI - FPGA problem and found only one hint.
An other customer had the same problem, and he tried a new BIOS version.
It seems that this solved his problem, because he was very satisfied.
So please try to install the new BIOS.
Hope this helps.
Best regrads
Dippi
(5,578 Views)
thx for your advice.
I've tried the 1.50 you've sent me and a 1.81 BIOS Version which i've found on your ftp:
now i have a lot of additional configuration options, but the errors are the same.
our local PXI-Support thinks that the Controller is wrecked, we've got a new one 🙂
regards, mike
(5,381 Views)
