PXI
Routing signal through PXI_Trigger to RTSI
PXI-6224 DAQ Generates a pulse through CTR0/PFI12 port. When the pulse reaches its trailing edge,PXI-5122 digitizer starts to acquire a voltage waveform.
I think it should be done with routing signal through PXI_Trigger to RTSI,like my vi attached. But to the item I test,there is no referenced result,I am not sure if its result correct,even though the vi works OK. Please help me check it,thanks.
Windows XP SP2+LabVIEW 7.1
Message 1 of 1
(3,058 Views)
