PXI
SCXI 1314 Sampling rate
We are trying to collect strain gage information using the SCXI-1314 module.  This is connected to an SCXI-1520 module mounted on SCXI-1000 which then reads into a LabView program to collect the data.  We were wondering what the maximum sampling rate for this setup is.
Thanks for the help
(4,377 Views)
Hi dbaer,
Your SCXI-1520 is going to be connected to an analog input DAQ card of some type. This DAQ card is what does the actual sampling and is what governs the sampling rate. Once you figure out what kind of card you have (either in your PC or PXI chassis) you can then look in the spec sheet to determine its sample rates.
Hope this helps!
(4,340 Views)
