PXI
SCXI Channel Scanning
When I turn off my SCXI and turn it back on, the channels do not start to scan right away. I have to make it "click" for it to start. I am able to acheive a "click" by changing settings on that specific module. Once I hear a "click" from the SCXI the channels start to scan. How do I configure it to start scanning channels right away when I turn the SCXI on?
(3,452 Views)
Sargon;
The delay you are seeing there is due to the fact that the SCXI channels need to be configured before the Scan process starts. The configuration of the channels are need everytime the chassis is turned off.
Since the configuration task takes a small while, you will always see a delay before starting to Scan the channels.
Regards
Filipe A.
(3,452 Views)
