PXI
SHB4X-B4X Cable Pinout
We will be using your SHB4X-B4X Infiniband cable to connect your PXIe-4492 to a custom PCB in a test panel.
What I am looking for is the pinout of the SHB4X-B4X infiniband cable (197516-01) so I can make sure we design our custom board with the correct pinout.
We are also using your SHB12x-B12X Infiniband cable and it mentions that one end is the reverse of the other.  so that is why we are asking this question.
As far as the SHB12x-B12x cable this is what we have came up with for the first few pins:  (is this correct?)
PXI-6551 Description 192344-01 end 1   192344-01 end 2    779157-01
Pin 1        GND            Pin 1                    Pin 73                 Pin G1
Pin 2        PFI_1          Pin 2                    Pin 72                 Pin S1
Pin 3        PFI_1*         Pin 3                    Pin 71                 Pin S2
Pin 4        GND            Pin 4                    Pin 70                 Pin G2
(5,184 Views)
