PXI
SLSC System configuration
I am configuring a HIL System for which I require FIU therefore as recommended by NI I am using SLSC-12001 Chassis and the SLSC-12251 & 12252 Module. The RTI-12306 is used at the Back of the module for Fault Bus, I want to understand how the current sense channels used and the MDR Connector connections available on RTI-12306. What will be the output received from the Current Sense? I am not able find any good documentation for these modules. Can someone help me with some resources?
All I found is this manual which is not entirely clear
https://www.manualslib.com/manual/1468904/National-Instruments-Slsc-12251.html?page=18
Message 1 of 1
(443 Views)
