PXI
SSR backplane and PXI 6515
I have a SSR backplane 16-modules with input modules  70-IDC5.
This backplane is connected to the board PXI-6515 with R1005050 cable.
The problem is that the input modules are reading well the signals, but the backplane is putting all the signals in the output pins of the PXI-6515, instead of the inputs.
Isn't possible this combination? (SSR backplane + R1005050 + PXI-6515)?
Thank you!
(3,351 Views)
Dear Yabune,
Thanks for posting on the National Instruments Forum.
Unfortunately it is not possible to connect your SSR 16-module backplane to your PXI-6515. As indicate on this link you can use a PXI-6508 with a SC-205X.
    Benjamin R.
Senior LabVIEW Developer @Neosoft
(3,332 Views)
