PXI
Searching for a cable terminal block combination that works with the PXI-2568
Has anyone figured out a cable-terminal block combination for the PXI-2568. I have a hard time finding something useful and would appreciate any part/supplier information from users who purchased a PXI-2568. Thanks.
(3,287 Views)
If you download the specifications document for the PXI-2568 from NI's website there is a section close to the end that talks about cabling and accessories. The PXI-2568 uses a standard 62 pin D-sub connector. The cable and terminal blocks for this connector can be found at large electronic suppliers. I hope this helps and have a great day!
Bryan Snarr
Application Engineer
Bryan Snarr
Field Engineer
Northern California
(3,277 Views)
