PXI
Setup LIN as slave on veristand
How to setup Veristand setup as LIN slave device? How to make veristand setup respond to the master LIN header messages?
Please point me the resources if any.
(2,300 Views)
After you add your LIN port to the SDF and specify the LIN database you want to use, there is a checkbox for specifying if the port is a master or slave.
As long as your database (LDF) file has the correct frame, signal, and schedule information, then the port should respond to master header messages based on the frame ID in the header message.
What specific problems are you running into? If you want to see a good example of a LIN database, open the NIXNET_exampleLDF database in the XNET Database Editor.
-Jordan
(2,250 Views)
