PXI
Shutting down PXI-1042
I have a PXI-1042 with a PXI8840 controller running on windows.
When I shutdown window  the controller 'shuts down' but the chassis keeps running and I physically require to press the power button to switch it off.
Question:
Is it possible to power down the chassis via the controller itself once it shuts down (ie when I as windows to shutdown)
Thank you for request my post! 🙂
(530 Views)
Accepted by topic author sherzaad
PXIe (PCIe) has access to a wake signal which enables the system’s main power rails and reference clocks. The controller handles the wake signal and controls the power-up state of PXIe chassis.
This signal and feature are not available in PXI (PCI).
https://tmesystems.net/
(509 Views)
