PXI
Simulated PXIe-2525 Device exist?
Does Simulated DAQmx PXIe-2525 Switch device exist or could we get/add it some way?
Seems that my NI-Switch 2023 Q3 installation did not add it at least. Attached you can found the "252" devices that exist for simulation configuration in my installation.
(726 Views)
Accepted by topic author JouniR
There are some switch modules that are not supported by NI MAX for simulation and PXIe-2525 happens to be one of them unfortunately.  You can simulate it in LabVIEW using the niSwitch Initialize With Topology function. However the simulated settings are not saved in NI MAX for future reuse. You can follow the link below for more detailed explanation.
https://forums.ni.com/t5/LabVIEW/Not-able-to-create-Simulated-Switch-for-NI-PXIe-2738-in-NI-MAX/m-p/...
Hope this answers your question!
(396 Views)
