PXI
Simultaneous Drive Limit
Hi All,
Here I am facing an issue. I am trying to connect relays using PXI 2510 but the problem is i am not able to set or close more than 38 relays(Simultaneous Drive Limit-SDL) eventhough it supports 212 relays. If i try to connect above this limit my device becomes disabled.This simultaneous drive limit varies with different PXI (for 2720 it is 89 relays) and some PXIs don't have this. So now i want to find this simultaneous drive limit to restrict the connection before setting the relays to avoid disabling of the device. Is there any way to find this  simultaneous drive limit in runtime?
Hari Prathap
Message 1 of 1
(4,564 Views)
