PXI
Slot numbers of the PXI-Daq devices are not shown in MAX
I have 5 4472 devices & Counter card in my PXI-1006 chassis,Iam able to see the slot numbers of first two devices,from the next device iam not able to see the slot number of the device in MAX.If the device number of the first two devices are 2 & 3,the third is not showing 4,its showing 5.
(3,248 Views)
Murali,
You mentioned both pxi slot numbers and device numbers in your question. If you are having problems with the pxi slot numbers of your boards, you should verify that you have the correct PXISYS.INI file on your system. You can download the proper file for your particular system below:
PXISYS.INI Files
Spencer S.
(3,248 Views)
