PXI
Specify Chassis Slot in Example Project
Hope this is the right location for this question: new user here, trying to get a PXI-5402 in a PXI-1031 up and running. I have used MAX, and the generator itself is working fine. But now I'm trying to take an example for Visual Studio provided with FGEN and modify it to operate the PXI-5402 programatically.
The "Basic Signal Generator" example creates a user form with a "scope" where I can modify the frequency, amplitude, etc. and see the result on the scope. But there's no hook to the actual PXI-5402 hardware. How do I modify this example program to get an actual output on the PXI-5402?
Thanks!
(4,090 Views)
Can you upload the example code that you are using?
Rachel P. | Applications Engineer | National Instruments
(4,044 Views)
