Home
Community
Discussion Forums
Most Active Hardware Boards
PXI
Topic
PXI
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Specs for memory on PXI-8174
RadTek
Member
02-27-2004
05:50 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
All I can find is the recommendatation that I spend 500 for NI-tested memory. At that price I can test a lot of memory. Can someone give me the specs for the SODIMMs?
EcoCAR Advisor
0
Kudos
Message
1
of 2
(3,101 Views)
Reply
Re: Specs for memory on PXI-8174
Sonya W.
Member
03-02-2004
11:08 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
The following KnowledgeBase lists compatible types of RAM from other vendors:
RAM for NI 8171 Series Controllers
I hope this helps!
Sonya W.
Applications Engineer
Kudos
Message
2
of 2
(3,101 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
