PXI
Standard PCI-to-PCI bridge cannot find enough free resources that it can use. (Code 12)?
Hi everyone,
Finally I solved my problem "PCI BRIDG code 12" I had sleepless nights just to fix this problem.
at the end and with some testing I was able to know the source of the malfunction how is to check the speed of your RAM.
If you have 2 different RAM Frequency try to change them to get the 2 RAM of the same Frequency.
Try also to have the higher frequency of RAM that is compatible with the motherboard.
that all.
sory for my bad english.
Message 11 of 12
(1,456 Views)
I had the same error message when connecting PXI-1042 Chassis with PXI-8360 ExpressCard on an HP notebook with a customized for our company Windows 7 OS.
I had to enter the BIOS configuration and disabled all hardware I was not using at the moment such as RS-232, USB ports, flash memory card slots, SATA ports. After resetting the computer, MAX was able to detect my PXI chassis, it also got rid of all the warnings in Windows Device Manager related to the PCI-to-PCI bridge.
It also added, although they have warnings, the PCI devices installed on my chassis. I am now installing the specific drivers for each card.
Next step will be to enable hardware I actually might need and see what happens.
Message 12 of 12
(1,419 Views)
