PXI
Start SCOPE adquisition by using trigger exported by FGEN in python
I am trying to generate a ARB waveform with the FGEN and start the adquision of the SCOPE at the same time. It doesn't work because look like the SCOPE never triggers and at the end there is a timeout error.
I enclose the demo code that should reproduce my problem.  Is there any similar code example or someone could point out what I am doing wrong?
Thanks!
import nifgen
import niscope
from nifgen import enums
from niscope import enums as scope_enums
options = {'simulate': False, 'driver_setup': {'Model': '5433 (2CH)', 'BoardType': 'PXIe', }, }
fgen = nifgen.Session(resource_name='FGEN', options=options)
fgen.abort()
# prepare the scope to be triggered with the exported trigger from the FGEN
scope = niscope.Session(resource_name='SCOPE')
scope.channels[0].configure_vertical(range=4, coupling=niscope.VerticalCoupling.DC)
scope.configure_trigger_digital("PXI_Trig0", slope=scope_enums.TriggerSlope.POSITIVE)
scope.configure_horizontal_timing(min_sample_rate=int(60e6), min_num_pts=180000,
ref_position=50.0, num_records=1, enforce_realtime=True)
scope.initiate()
# generate a WAVEFORM
sample_rate = 10E6
waveform = []
for i in range(0, 1000):
waveform.append(i/1000)
fgen.output_mode = nifgen.OutputMode.ARB
fgen.channels[0].arb_sample_rate = sample_rate
fgen.channels[0].trigger_mode = enums.TriggerMode.SINGLE
waveform_handle = fgen.create_waveform(waveform_data_array=waveform)
fgen.exported_start_trigger_output_terminal = "PXI_Trig0"
fgen.arb_waveform_handle = waveform_handle
fgen.streaming_waveform_handle = waveform_handle
fgen.channels[0].configure_arb_waveform(waveform_handle=waveform_handle, gain=2, offset=0)
fgen.initiate()
while fgen.is_done() is False:
pass
wfm = scope.channels[0].fetch(num_samples=180000)
wfm = list(wfm[0].samples)
print('Number of samples acquired: {:,}\n'.format(len(wfm)))
fgen.abort()
scope.abort()
(3,208 Views)
Hi ihouses,
can you please tell us what scope you are using?
Best,
Melanie
Melanie Eisfeld
Senior Applications Engineer, National Instruments Germany
Certified LabVIEW Developer
Certified TestStand Architect
(3,182 Views)
I have a scope NI PXIe-5105, and I want to trigger capture and read channel 0
(3,177 Views)
Hi ihouses,
concerning the Specifications document of the PXIe 5105 the device only supports a Reference Stop Trigger:
PXIe-5105 Specifications - PXI Oscilloscope Manual - National Instruments
http://www.ni.com/documentation/en/pxi-oscilloscope/latest/specs-pxie-5105/specs/
You should get an error message as sson as you configure the trigger setting for the scope or when you start the scope telling you the start trigger is an unsupported feature for your scope.
Best,
Melanie
Melanie Eisfeld
(3,168 Views)
As you can see in the code I am using the digital trigger. That is specified in the like that you provide:
Digital Trigger
Trigger type
Digital
Sources
PFI 1 (front panel SMB connector)
PXI_TRIG <0..6> (backplane connector)
I my case I use PXI_TRIG0
I don't know anything about the reference stop trigger.
(3,165 Views)
Well, that's embarrassing but suddenly the script works in my setup. May be is because I reset the machine or so. So thanks for the support.
(3,137 Views)
