PXI
Status code: -225130 Internal hardware Error occurred in Power_Supply Hardware
I have a PXI system with the following hardware:
PXIe-1083 chassis
PXI-2535 switch board
PXIe-4141 SMU board
I encountered this error:
Status code: -225130 Internal hardware Error occurred in Power_Supply software. Please contact National Instruments Support.
I did a little research on the message board and found two posts below. I tried upgrading PC BIOS but it didn't solve the problem. My PC uses a Thunderbolt 4 card. Please help!
https://forums.ni.com/t5/PXI/NI-DCPower-17-Error-225130-Windows-10/m-p/3719649#M17617
https://forums.ni.com/t5/PXI/Status-Code-235140-Internal-Hardware-Error-occurred-in-Power/m-p/426199...
Amy
Message 1 of 20
(3,000 Views)
Knowing more details about your system and the full error message would help a lot. If using Windows, a MAX Technical Report would go a long way toward answering basic questions.
When does this error occur? Are you able to reproduce it reliably, or was it a one-off? What is the full error message?
Does the PXI-2535 work correctly?
Have you tried switching slots?
Thunderbolt controllers are notoriously problematic with implementing the PCIe specs correctly. Check for an update for your Thunderbolt controller as well.
Tobias
Principal Software Engineer
Driver Software
Message 2 of 20
(2,997 Views)
Hi Tobias,
Thank you so much for your quick reply!
Yes, the error shows up every time I run my code and it didn't let me to continue.
I am not sure if switch works because I can't see result from switch alone.
I was using the most updated Thunderbolt driver. After seeing the previous post, I have downgraded the Thunderbolt driver yesterday. It didn’t solve the problem. The only difference is the error message changed from -235140 to -225130.
Attached is the MAX report.
Yimin
Message 3 of 20
(2,984 Views)
Thank you, that MAX report is helpful.
Please list the full error message. Simply having the error code without further context is of limited value.
Provide a simple reproduction case. That will help narrow this down further. Not knowing what your code is doing is challenging.
Are you able to try a non-Thunderbolt chassis?
Was this working before?
What does Reset Device from MAX report? Does it pass, or a similar error?
Are you able to Initialize the NI-SWITCH instruments in your system, or do they error out too?
You have some 2017-era driver versions. Can you upgrade them?
Is there any change in behavior if you move the instrument to a different PXIe slot?
Please try all these and report back with your results.
Tobias
Driver Software
Message 4 of 20
(2,942 Views)
Hi Tobias,
Here is the full error message. I'll try to come out a simple test case which reproduces the same error and share with you.
The system works well on my laptop which has a built-in Thunderbolt port. But it never works on my desktop PC that has a Thunderbolt PCIe card. But we do need it work with the desktop PC.
Does NI have non-Thunderbolt chassis which can work with those switch matrix and smu cards? If you do, I would like to try. Thanks!
Yimin
Message 5 of 20
(2,923 Views)
@AmyJing wrote:
Hi Tobias,
Yimin
Unfortunately what you are seeing is expected. From Connect PXIe System With Thunderbolt™ Interface Card
Our Thunderbolt™ devices are primarily designed to work with third version Thunderbolt™ and/or ports that are built-in on the motherboard. Therefore, please be aware that all third-party PCI/PCIe add-ons are not officially supported and recommended by NI.
You can opt for MXI remote controller, but there is a possibility that you will still encounter with enumeration issue and you will have to go thru MXI-Express Compatibility and Connectivity Troubleshooting Guide
The best way is to get the PXI controller and chassis.
https://tmesystems.net/
Message 6 of 20
(2,895 Views)
Hi ZYOng,
Thank you so much for your reply! It saves me a lot of time of trying to figure out what went wrong with my system. I'll try to buy a Thunderbolt 3 card and give it a try.
Yimin
Message 7 of 20
(2,850 Views)
Hi Yimin,
Desktop PCs with Thunderbolt add-in cards are commonly misunderstood. It is likely your add-in card hasn't been installed correctly, or it is not supported with your system. I suggest you first verify with Dell the Thunderbolt 4 add-in card is actually supported by your specific system. If it is supported, verify you have cabled it correctly. Thunderbolt add-in card typically require an external cable from your PC's DisplayPort output going into the DisplayPort input of the Thunderbolt add-in card, and it requires additional cabling internally going to the motherboard.
Best,
Nick
Message 8 of 20
(2,839 Views)
Hi Nick,
Thank you so much for your input!
The Thunderbolt 4 card are from Dell. I purchased a new Dell desktop for this project. The card was actually installed by Dell. I checked device manager and it seems working properly to me. I also checked the motherboard and made sure that the internal cable was plugged into Thunderbolt connector on motherboard.
Now I need to find a cable to connect the DP port as you directed. Could you please explain a little more why we have to make this connection? Thank you very much!
Yimin
Message 9 of 20
(2,834 Views)
Hi Yimin,
Thunderbolt is designed to carry both PCIe and DisplayPort with a single cabled link. It is designed primarily so that a single cable can be used by laptops to connect to a docking station and link monitors (DisplayPort) and peripherals (PCIe).
Thunderbolt add-in cards for PCs are connected internally to your system through a PCIe slot, so it has half the requirement for Thunderbolt, but it does not have the other half without a DisplayPort connection. This is why the external DisplayPort cable connection exists. The solution is not user friendly, and the add-in cards cannot be bought and used on just any PC.
Best,
Nick
Message 10 of 20
(2,828 Views)
