PXI
Support technique NI PCI DIO 96
Madam, mister;
I have a question concerning the pinout of the NI PCI 96 DIO card.
The 99th pin is a +5V. Is it an input or an output. To my mind is an output, Could you confirm ?
If it is an output, could you tell me the Imax value supporting by the card ?
Best regard
(3,569 Views)
The pin 99 is fused for up to 1 A total of +4.65 to +5.25 V
You can find this information in the manual od the PCI-DIO-96 :
http://digital.ni.com/manuals.nsf/websearch/7DEF0FD892730E198625665E00635874?OpenDocument&node=132100_US
regards,
Marc Larue
NIF
(3,562 Views)
Thank you for this information, so in fact with the NI PCI DIO 96 we have 2 output +5V/1A ?
Best regards
(3,554 Views)
