PXI
Swapping out an old PXIe system
We have an old PXIe-1062Q chassis with a PXIe-8108 and two PXI-6238 installed.
The current system is running on an outdated Windows version (Windows 7 Professional).
We are considering upgrading to a newer system, using the same type of components, and a more recent version of Windows.
If we transfer the same program from the old system to the new one, will it function properly with the updated Windows version?
If so, what is the latest version of Windows that will support it?
(589 Views)
Officially, PXI-8108 does not support Windows 10. Reference: Solved: Is there a chance to install Windows 10 (64-bit) on a PXI-8108?
For driver compatibility, you can check NI Hardware and Software Operating System Compatibility
https://tmesystems.net/
(570 Views)
