PXI
Switch NI HDD-8262 RAID Array from old computer to a new computer
I have a NI HDD 8265 RAID Array connecting to NI 8282 card in a chassis which is connecting to a computer. The hard drive has 3 partitions and and data. Now I'm going to reconnect the chassis a new computer (windows 10). How should I do to install the device and setup the new computer to be able to see all exist partitions and data from the RAID Array?
Thank you.
(2,872 Views)
Do you have the new computer set up with the correct RAID drivers? The link below details how to do this for the new computer.
Installation of the Driver for the NI HDD-826x RAID Array
I would back up files if possible before looking at migrating. Also note to skip Step 9 if you have previously partitioned your RAID drive.
Best,
Chris D. | Applications Engineer | National Instruments
(2,811 Views)
Hello,  one of my external drives has caused an internal error and we believe the data has been corrupted. We bought another External hard drive to relpace this. It doesnt say exactly on the manual of Getting started how to do this.
Secondly, before changing one drive, do i have to backup all the other 11 drives ? And since one drive has gotten corrupt, does that mean all the data in the other hard drives are corrupted since one is corrupted?
Can i reformat the new HDD on a widnows 10 computer or is better that i do the reformatting directly through the same windows 7 PCIe chassis ?
(544 Views)
