PXI
Sync multiplexer and DAQ operation
HI all.
Currently Im using a 2530 PXI multiplexer in a octal 16x1 topology and an 8 channel 6466 PXI Daq,
I have a repeating waveform at 5Hz and i require to conduct the swich operation at the end of each period to change what the AI is measuring.
The Daq is set up as a continuous regeneration of the waveform to output from the AO and also reads the data on the 8 AI channels.
I have tried sending a software trigger to the multiplexer (using NI-Switch) but, although this occurs at 5Hz, the switch happens ~200ms into the waveform period.  This is in the same loop as the DAQmx read vi
How can i configure this to switch at the end of the period?
(3,494 Views)
Hi Gorgy,
Are you able to post your code so I can look at it? Have you tried hardware triggering the multiplexer?
James
James Kent | Applications Engineer | National Instruments UK & Ireland
w: uk.ni.com | ireland.ni.com
(3,465 Views)
