PXI
Synchronisation between 2 PXI via MXI-4
I would use severall PXI chassis linked with MXI-4.
Is MXI-4 compatible with the RTSI synchro lines of PXI ? Or do I use an external trigger to do that ?
Thanks for answers.
Matth
(3,458 Views)
You can not use the MXI 4 card to make a synchronization.
There is several ways to synchronize PXI chassis.
This is some links wich can interest you:
http://digital.ni.com/public.nsf/websearch/6BC7EAF3153334C286256D0A004FA9D9?OpenDocument
http://digital.ni.com/public.nsf/websearch/64154143B6B898AA86256C2B006D11CC?OpenDocument
http://digital.ni.com/public.nsf/websearch/CA9A49FA50393C4186256DC200774E2B?OpenDocument
Johan G.
NIF
(3,405 Views)
Thank you for your answer.
I cant' use PXI-6651-6652-6653 because there is about 40 meters between 2 PXI chassis.
It seems to me this is a very long distance for the use of an external clock, but I'm going to try an external trigger to synchronise the start of the 3 acquisistions.
If somebody has another idea ...
Matth
(3,402 Views)
