PXI
Synchronising arbritrary function generator and niscope
I am trying to generate signals 2 signals using an arbitrary function generator and receive this using an NISCOPE.
Arbritraty function generator:
Signal ch1 out  1: Segment 1: Ramp (125 Hz) + Sine(20kHz) -duration 8 ms; Segment 2: Ramp 125 Hz(duration 8 ms)
Signal ch2 out: Sine 25 kHz(16 ms long)
Trigger at start of Ch1 and Ch2.
Optimal sampling rate : 2 MS/s
NI scope:
Receives the two-channel outputs from the arbitrary function generator. with the trigger to start acqisition.
The sample clocks should be the same for both the function generator and the scope.
acquisition mode should be continuous.
Attached is the file application.
Please share a NI vi example for the function generator I can use (currently I am using an external function generator for this application).
I think I can share the PXI 10 MHz clock between the two.
Thomas
(2,062 Views)
I have attached a sample VI for generation. Let me know whether it works for you.
Thanks & Regards,
Tarandeep Kalra
(1,946 Views)
Hi could you attach the VI in labview 18.0 or earlier?
Thomas
(1,941 Views)
