PXI
Synchronization Issue Between STM32F407VGT6 UART TX and PXI Pattern in Digital Pattern Editor
Hello NI Community,
I am currently working on validating the UART protocol using the Digital Pattern Editor with a PXI-based system. My Device Under Test (DUT) is an STM32F407VGT6 microcontroller, and I am transmitting UART data from the STM32 to the PXI hardware.
Issue Description:
While attempting to capture UART data sent from the STM32 using the PXI Digital Pattern Instrument, I am facing a synchronization issue. The PXI pattern does not seem to reliably align with the UART transmission from the STM32, resulting in invalid or missed data captures.
What I Have Done So Far:
  • The UART baud rate is configured at [mention baud rate, e.g., 9600/115200] on the STM32.
  • I have created a pattern in the Digital Pattern Editor to capture the UART waveform using a match() opcode followed by a repeat() to sample the bits.
  • The trigger (start bit) is configured using match() on a falling edge (Idle High to Start Low transition).
  • I am using repeat(79) or similar values to delay sampling to the middle of the data bit period.
Problem Observed:
  • The PXI capture pattern either starts too early or too late.
  • In many cases, the pattern completely misses the UART frame or captures incorrect data.
  • I suspect that the issue is due to lack of proper synchronization between the STM32's asynchronous UART transmission and the PXI pattern's start.
Questions:
  1. What is the recommended method to synchronize the pattern start with an external asynchronous UART transmission?
  2. Should I use an external trigger line from STM32 GPIO to the PXI system to trigger pattern start?
  3. Are there recommended practices for reliably capturing asynchronous UART with PXI instruments and Digital Pattern Editor?
Message 1 of 1
(150 Views)
