PXI
Synchronize PXI 4462 & 4472
The system setup is:
1. PXI-1033 chassis
2. Slot 2 - PXI-4462(DAS)
    Slot 3 - PXI-5412 (AWG)
    Slot 4 - PXI-4472 (DAS)
We are measuring 5Hz - 25kHz. We are particularly interested in the phase difference between the 4462 & 4472 measurements.
I need to synchronize the 4462 & 4472. Is this possible with this setup? My understanding is that the  PXI Chassis 10MHz clock must be used for both te 4462 & 4472 and the Star Trigger is also required. I think I read that the DAS must be both in slave mode for this to work. How could I accomplish this? Is there a labview DAQmx example available? thanks
(2,231 Views)
Hello davidhi,
I am not entirely certain if this will solve your problem, but this page (https://www.ni.com/en/support/documentation/supplemental/10/synchronization-explained.html) has a lot of good information on synchronizing DAQmx events via clock synchronization and designating master/slave tasks. Figure 8, for instance, might be of help.
Best of luck!
(2,203 Views)
