PXI
Synchronize SC Express and S series cards on PXI
Hello All,
 I am trying to synchronize the start of continuous acquisition on multiple SC Express (PXIe-4331) and S-Series (PXI-6143) cards on a single PXI chassis. Right now I am using the method described in tutorial 3615 figure 2: exporting the AI start trigger terminal on the PXIe-4331 in Slot 2 to the PXI-6143 cards on the second task. I'm getting a delay between the returned data of about 0.4ms, though. Is there a better approach than this? See code snippet.
Thank you!
(6,027 Views)
Hello GatorMech89,
Could you point me to the tutorial you are following? Do you have the link?
I would like to check that reference, because here you are sharing the start trigger but I do not see other kind of synchronization. I would like to check the hardware capabilities because you want to synchronize cards from different families. Just let me know if you have that reference.
Regards
Frank R.
(6,004 Views)
Sorry for the delay...conferences are certainly a great way to interrupt important tasks!
https://www.ni.com/en/support/documentation/supplemental/21/m-series-synchronization-with-labview-an...
This paper applies to M-Series devices but following its principles have gotten me close so far. Just wondering what I am missing.
(5,977 Views)
Hello GatorMech89,
Using this document (Synchronizing S Series) and this other one (Synchronizing SC Express Devices) as references, we can discard a reference clock synchronization. I think you could try a sample clock synchronization.
Here I linked below a couple of examples to do this kind of sync. They do the same in different ways.
https://forums.ni.com/t5/Community-Documents/Sync-DSA-SC-Express-and-MultifunctionDAQ-Card-in-One-PX...
Regards
Frank R.
(5,967 Views)
